air control valve on cougar
3/31/19
chich Member
Sorry to make a new post out of my original , however Herb Johnson advised me how to replace and install the air controller know on my cougar gun and I really dont understand what he means. Something about dont screw it in all the way. I really dont understand what he means and my new part is due any day so i would like to install it correctly. I m sure its a no brainer but thought id ask u guys for advice
4/1/19       #2: air control valve on cougar ...
Robert
With all respect and nothing then advising solid info, wondering why simply don't you ask CAT directly ??
Best at advising you on your gun, they make it !!
All the best
4/1/19       #3: air control valve on cougar ...
chich Member
robert i surely did that but never mentioned it.. I knew they would tell me there was no way i could screw that part on wrong so i figured i wasnt grasping what Herb Johnson was talking about so I made a seperate post. My original post I believe was "precat buildup" i believe
4/1/19       #4: air control valve on cougar ...
Brewster201
I would just try to purchase a Kremlin Xcite 120 gun. Super easy to clean and rebuild.
Sprays absolutely fantastic
There is also way more info on this gun
4/2/19       #5: air control valve on cougar ...
herb johnson
sorry for the delay
the fan air control comes as an assembly as i recall the knurled knob and the male piece that screws into the body of the gun... unscrew the the male piece of the fan controller then screw in the fan controller, then when assembled, back the controller alll the way out when your screw the assembly into the gun, so that there will be a gap between the front end of the fan controller and the seat where it goes into the front of the gun, sometimes the because the clearance is so tight a tapered needle and seat you can end up overtightening things and bend the shaft, sometimes my guys do this because they think they are tightening hydraulic fittings that are 20k psi, i have noticed that my kremlin guns are notorious for bending the fan pattern adjustment rods
good luck
herb j
4/2/19       #6: air control valve on cougar ...
Brewster201
The fan pattern rods get bent because people forget to retract the rod when screwing in the assembly when rebuilding
A real rookie issue
4/2/19       #7: air control valve on cougar ...
herb johnson
exactly and its a damm costly mistake, i have spent hundreds on these damm things
and there is nothing on any mfg tech sheets that mentions it.
and unless you are writing the chekcs and really look into it you really won't know what is causing it
there are made out of monkey metal and trying to straighten them is almost not worth the effort mostly even with light effor they snap
good luck
herb j
4/6/19       #8: air control valve on cougar ...
chich Member
Thank you Herb and the rest of you pros as well.. I put the new air control valve on but I guess that wasnt the problem as the Campbell rep said. gun still leaking air at rest. who knows
4/8/19       #9: air control valve on cougar ...
Shane
Leaking air at rest... you need to replace #14 air valve
And the gasket at #15 per your gun part pdf listed for the cougar gun...
