Is this fisheye in my Poly Varnish?
4/30/19
Romain Member
Hi woodworkers,
This is a 24 mm Plywood (B grade poplar I believe) with solid oak 24 mm edges and rotary cut veneer on both side.
The dye is waterbase aniline.
I am having endless issues with this top. Already had to strip the veneer down once because I was sold rotary cut bookmatch oak veneer sheets. (I discovered that only one face is good the other cracks with such veneers)
I am using one part Poly varnish with the most decent "varnish brush" I have found here in Portugal (Forget about any quality tools here I have to import everything but sometimes you just have to do with what is around).
I sanded down with 400 grit (I only had this probably should have gone with 300), and I am having this horrendous aspect. the last coat already had done orange skin due to my attempt at using a sheepskin imitation roller but I sanded it down.
I diluted my poly with approximately 1/4th of PU thinner. I did nottice that it was extremely hard to apply and tacky (was it diluting the previous coat?).
I sanded with what I think is Silicone Carbide sanding paper and heard about sililcone contaminitation. Could it be the case?
I am quite desperate to find a solution as the amount of time spent on this piece has already reached "Legendary".
View higher quality, full size image (1125 X 1500)
View higher quality, full size image (1500 X 1125)
View higher quality, full size image (2124 X 2832)
4/30/19       #2: Is this fisheye in my Poly Varnish? ...
Pat
Yes, that looks like fisheye. Silicon and silicone are not the same thing. That said, certain types of abrasives were often blamed for fisheye in the early days of waterbased finishes.
A good practice is to make samples with your full finishing schedule before applying them to the real item. You could try using a different sandpaper or applying a coat of dewaxed shellac as a sealer before the poly. What actual poly product are you using, and are you sure you're using the correct thinner for that product?
Cheers,
Pat
4/30/19       #3: Is this fisheye in my Poly Varnish? ...
Romain Member
thank you Pat,
Here are more info about both products. I did buy them in 2 differnet suppliers. Sorry it's in Portugese but probably chemistry is international.
First is thinner I used
Second is the one part Poly it is solvent base not water base.
Many thanks
View higher quality, full size image (891 X 461)
View higher quality, full size image (808 X 847)
4/30/19       #4: Is this fisheye in my Poly Varnish? ...
Romain Member
I understand I should have sealed before applying the PU now, but what would you recommend doing at this point.
The fact that I applied a water base dye is tricky because I can't strip the finish down.
Should I just sand the varnish until I remove the craters and wipe on diluted 50/50 poly thinner ? if the thinner is the correct one obviously...
4/30/19       #5: Is this fisheye in my Poly Varnish? ...
mauricio poli Member
Hello Romain!
Let´s do the following, to discover why are you having fish eye.
In another panel , apply you water based green stain in a half, the other half do no apply color.
Let it dry and apply you varnish with the indicated thinner.
Try to use a new brush.
This way you´ll understand who is creating fish eyes.
It is sad to say it, but you will need a lot of work to eliminate all the defects.
Try to use those kind of sanding sponge, maybe you could find in your city...
https://www.google.com/search?q=fandeli+esponjas&tbm=isch&source=iu&ic
tx=1&fir=Lkh9fxRzuK3-6M%253A%252ClHMQjNN48MCmRM%252C_&vet=1&usg=AI4_-
kRIZUchwdK7xUDuthyOGYBrtDe9Jw&sa=X&ved=2ahUKEwibk9eT_fjhAhVmIDQIHSaOCtgQ9
QEwBnoECAkQCg#imgrc=Lkh9fxRzuK3-6M:
Good luck
4/30/19       #6: Is this fisheye in my Poly Varnish? ...
arthur grudko
If you want to be done with this, try the following.
Make a sample with the same veneer and dye. Get some fisheye killer (also known as lacquer smoothie), a silicone that will compatibilize whatever is causing the fisheye in your poly. This is how this problem is resolved with lacquer, and it should work with solvent poly as well.
4/30/19       #7: Is this fisheye in my Poly Varnish? ...
CraigM
Your coats look pretty heavy for an open pored wood like oak, it could be solvent pop which can sometimes appear similar to fisheyes. Try thinner coats with and make sure the coats are fully dry before the next one goes on.
