Fan Location in a Paint Booth
5/20/19
John Member
Hello,
I am relocating my paint booth to a new building and need to move the exhaust fan from the top to the back of the booth.
Is this doable?
It is a 14' x 27' enclosed booth. 36" piping. Any advice is welcome. Thanks
5/20/19       #2: Fan Location in a Paint Booth ...
If the old location was centered, and now you move it 13.5' to one end, you will likely have some dead spots at the far end corners. You might consider adding some internal ductwork to the far end. My last shop had a modified down flow. There was a rectangular chamber along the floor all the way down both sides. Filter material covered the face of that chamber. Where are you planning to bring in the conditioned make up air?
5/20/19       #3: Fan Location in a Paint Booth ...
John Member
Here is a photo. Sorry for the crude drawing.
Is this doable?
5/20/19       #4: Fan Location in a Paint Booth ...
herb johnson
am a little confused is the fan going to be on the center line of the booth if so the fan will work well on the back wall of the booth but you might want to put some grating directly in front of the fan to make it pull from the side of the exhaust chamber ie put resistence directly in front of the fan, also consider putting the fan on the roof or on the outside of the building, put a weather proof disconnect so you can service the motor will make a much quieter booth also consider adding a variable frequency drive if you don't have one, most booths allow you to interchange the top booth panel with a rear booth wall panel
good luck
herb j
5/20/19       #5: Fan Location in a Paint Booth ...
Jared Emery
That's a semi-downdraft booth. I have one that was manufactured like that. Mine has a plenum underneath the fan that draws the airflow through two filter-wrapped columns at the corners. If you're redirecting the fan out the back wall, it shouldn't matter as long as it's still pulling the air through the plenum.
6/11/19       #6: Fan Location in a Paint Booth ...
I would agree with what Herb said, I have a booth designed by Global Finishing systems and the fan panel is designed to be interchanged with another panel and can go either in the roof or the back of the booth.
