Kremlin
8/31/19
Mike Member
I have one 15C25 Kremlin pump that I've been using to spray white lacquer. My question is, what are my chances of spraying clear finishes without any particles of white.
Thank you.
8/31/19       #2: Kremlin ...
About 100% chance of spraying without issues. I do it all the time. You need to make sure your screen filter at the bottom of the gun is in good condition and to use a screen in the tip, no matter what size tip you use.
I'll swap out from white to clear with a pretty shoddy clean up and it sprays fine. Just run 30oz of clear wash thinner through the system, clean out the lower gun screen and you're on your way.
9/1/19       #3: Kremlin ...
Mike Member
Log G, thank you for your response. I should be good then because I'm a fanatic about cleaning my system after use. One thing you brought up and that I am lacking and that is I need to insert the screen filter in the spray tip. Nice to know and proven by the pros that I don't have to buy another Kremlin.
Thanks again!!!
