Alder Finish Too Lite
10/3/19
Nick Cook
This is an interesting situation, I looked at a job we're going to match the finish on. It's knotty Alder. But somehow the existing finish on the cabinets is lighter that it would be with just a clear coat of lacquer. It's in an office for an optometrist. No real way for sunlight to hit all the cabinets, that was my first thought, fading. Also wondered if they have a cleaning service constantly wiping the cabinets with something. My question, what might be another possibility for why the cabinets are so light in color? We're working with Red Alder.
Thanks,
Nick
10/3/19       #2: Alder Finish Too Lite ...
Tyler
A white/pickle stain? maybe it was bleached?
10/3/19       #3: Alder Finish Too Lite ...
Nick Cook Member
It's not the pickle stain but bleach is a possibility, I don't think the finisher bleached it but maybe the cleaning crew after finish with a chemical cleaner.
10/3/19       #4: Alder Finish Too Lite ...
Nick
It's possible it's the finish that has turned white-ish as it ages. I've notice this on a couple waterborne clear jobs l've finished. It is very noticeable on jobs finished with Valspar's WB conversion varnish.
You should be able to get a pretty good match (at least in the short term) by mixing up a very thin white or white-ish stain over a wash coat or by toning.
Good luck.
10/3/19       #5: Alder Finish Too Lite ...
Nick Cook Member
Nick I'll pursue that, thanks for the input.
10/3/19       #6: Alder Finish Too Lite ...
Are you sure the material is actually Alder and not some import material that looks close enough to pass it off as Alder but isnt? Just a thought.
More and more as of late we are being asked to match a stated species that looks spon on but on closer inspection is... not.
10/3/19       #7: Alder Finish Too Lite ...
Bob Niemeyer  Member
If your using red alder and you use a thin white over it to try to lighten it. Well red and white = pink. Post some photos so we can offer some real help, not just guess on what to do.
10/3/19       #8: Alder Finish Too Lite ...
You sure it's not birch? The two species are related.
10/7/19       #9: Alder Finish Too Lite ...
Shane
very possible it's red birch and not Alder... or possibly built with a light batch of Alder... possibly bleached as well..... bleaching isn't that big of a deal either....
10/7/19       #10: Alder Finish Too Lite ...
Nick Cook Member
To give an update, I was unable to determine wood species, I'm convinced it's Alder, but we added some white tint to our lacquer and with two coats we achieved the same appearance. Another thing I'll add is that we looked at the interior of a door and it was the dead match for typical Alder with a clear coat. The light honey or amber color that car lacquer on Alder gets you. So something was going on with the exterior of these existing cabinets. Not sunlight, could be a cleaning agent, could be the original cabinets were bleached. It's in an optometrists business and I could see them regularly cleaning the cabinets with something that makes them fade.
10/7/19       #11: Alder Finish Too Lite ...
mastercabman
"Another thing I'll add is that we looked at the interior of a door and it was the dead match for typical Alder with a clear coat. The light honey or amber color that car lacquer on Alder gets you. So something was going on with the exterior of these existing cabinets. Not sunlight, could be a cleaning agent, could be the original cabinets were bleached."
Nick
It is very common for cabinets/furnitures manufacturer to only glaze/highlight just the front of doors/drawers
In a way it makes sense because the outside of the cabinet is exposed to everything but the inside is only exposed when the door is open
Glad you got it figured out
Good luck with your project
10/8/19       #12: Alder Finish Too Lite ...
No idea how a cleaning agent gets under the clear coat and alters the color of the wood, nor alters the color of a cured clear coat. Wouldn't it need to be very even coating over the entire number of cabinets to change all the colors exactly the same? I know you like the cleaning agent theory, but I'm very skeptical.
