Odd situation - Water Spots
11/6/19
Bit of a goofy question. Shipped a job to on of our contractors and part of it was a few sheets of raw plain-sliced Red Oak ply that they were cutting into panels, stain on site, and finish. While the sheets were on their job something happened either drywall finishers, or someone, splashed some water on the sheets that no one caught. Finishers sanded, and hit them with stain and typical water spot nightmare. They called and owned it and bought replacement material and the water spotted material was going in the dumpster and asked if we'd take it which we did.
By default on almost everything we do a water wipe to raise the grain and turn the entire sheet into a giant water spot just for cheap insurance to head this kind of thing off.
Coincidentally we have a dark stained job going at the moment that these panels could be used on though Ive never tried sanding back through the stain and water-wipe, and re-stain. My gut feeling is once the sheets were stained the water spots will be pretty much locked?
We took the sheets back thinking of chopping them up for stretchers or shipping material but wondering if there is some magic treatment that would eliminate or mellow the spots with a dark stain. The job we could use these on isnt super critical but the spots are somewhat of a diagonal splash so they stick out.
Thought I'd ask before we tried cutting a corner back and wipe/restain.
11/7/19       #2: Odd situation - Water Spots ...
Why put the labor into salvaging? Won't it cost more in labor than new plywood?
11/7/19       #3: Odd situation - Water Spots ...
Agreed. At 120 a sheet not considering any heroics. They'd just get chopped up. They'll be getting a sanding anyway and wondered about a wipe solution I had never known about but I've never been able to kill them in the past. The dark color and not a super critical job brought the thought of using it.
11/7/19       #4: Odd situation - Water Spots ...
Tyler
Only thing I can think of is maybe using a spray stain, so the water spots are irrelevant
