Furniture Making
Subject: Re: Spalted sycamore
Spalted sycamore
5/30/13
James Thomson
Website: http://Thomsontimber.co
As part of our business we supply large section wooden mantels for above wood burning stoves and have recently acquired a large amount of spalted sycamore. We supplied one to a over a year ago and the customer complained recently that it is has changed colour. How can I prevent this happening in future? We normally finish our mantels with 4 coats of danish oil. Can it be treated in some way to prevent the spalting process. Potential customers love the look of the black lines through the wood but I don't want any more complaints!
5/31/13       #2: Spalted sycamore ...
D Brown Member
The color change may be from oxidation
much like cherry wood or even Purple heart . Could it be the UV rays or possibly the finish you applied. Maybe try a film finish instead .
5/31/13       #3: Spalted sycamore ...
Rich
"Can it be treated in some way to prevent the spalting process."
Are you suggesting that it is spalting in the home? Impossible unless they are keeping is very wet, and wet all the time! And then the fungii will show as white or colored fuzzy growth, not more black lines, nor color changes. We don't know what brand of danish oil you are using, but WATCO has raw linseed oil and vegetable oil in it. Both of them oxidize and darken dramatically over time. Water based finishes stay very true to their original color, but for my taste, most look horrible unless tinted a amber. I would suggest a solvent based lacquer in the future. The film finishes won't be too happy over damp wood. Is the mantle kiln dried? No problem then.
5/31/13       #4: Spalted sycamore ...
James Thomson Member
Thank you so much for your input. I should explain a little further. The spalted timber mantel I supplied over a year ago had started to increase one of it's darker areas. It appears to have continued to 'spalt/decay' in spite of it's obviously dry/warm location. I have been investigating this further myself and suggestions made to prevent this situation occuring in future include:
Spraying with a fungacide or paint with a weak solution PVA glue, prior to finishing. The PVA option was probably more an attempt to help solidify some of the softer areas but may also prevent the two main fungal zones from trying to expand their area of infestation! I'm attempting the PVA method first as I have this readily available. Any other ideas appreciated!
5/31/13       #5: Spalted sycamore ...
Keith Newton
You can use a two part bleach, which will make all the wood whiter, but not the black line.
Then, I would use a really clear acrylic spray applying the first few coats really dry mist coats, sprayed from further out than normal, rather than really wetting it out. After it is sealed, you can go ahead and build a normal film coat if you feel like it needs it.
I've done that on some turned vessels, with good results.
6/1/13       #6: Spalted sycamore ...
Thanks for this advice Keith. As I have quite a lot of this type of timber and I will a few options on some small samples and decide which turns out best.
6/2/13       #7: Spalted sycamore ...
Jerry Fartwell
Are you properly drying your lumber? Or are you finishing and installing wet wood?
6/3/13       #8: Spalted sycamore ...
Hi Jerry, I see where you are going with this and you are probably correct! The timber we use for large section mantels tends to be quite freshly milled. We have started milling our mantel stock well in advance and leaving it to air-dry for up to a year. Because we make mantels in sections from 6"x4" up to 8"x8" we do no consider kiln drying. In our experience, all that happens is they tend to twist and crack quicker - due to the differential shrinkage between the centre and outside of such large sections! I agree that wet spalted timber will continue to spalt but had hoped it could be prevented in some way, other than having to wait an age for it to dry completely? I have heard of laminating layers of kiln dried wood but this is just cost prohibitive! At what moisture content would you suggest the spalting would stop? All ideas welcomed.
6/3/13       #9: Spalted sycamore ...
Scott Sober  Member
Website: http://www.cymafurnituredesign.com
Sorry to have to burst your bubble but If you continue to install wood at those dimensions you will have nothing but problems. There is no magic bullet to cure your problem. You need to drop the moisture content through the entire thickness to the point that the fungus becomes in active. One year is not enough. I would expect future problems for any thing you have installed since the wood will continue to lose moisture and change dimensions, split crack and other chaos. As to the finish oil will always cause the wood to darken, tung oil less so. You need to use a water white clear coat, water base would cause the least color shift I belive. Well good luck with your endevore. I hope I was at least helpful.
6/3/13       #10: Spalted sycamore ...
Rich
If you are putting wood in a house that is that wet, and partially rotten, color is only one of your problems. I'm shocked you haven't been called back for having bugs crawling out of it. You are really opening yourself up for trouble, including having to pay to have a whole house fumigated. If you need big timber dried quickly with no degrade, find someone with a vacuum kiln.
6/16/13       #11: Spalted sycamore ...
doug
Website: http://c.com
What is the ,moisture content of this wood?
6/17/13       #12: Spalted sycamore ...
bob
using spalted wood without drying is asking for big trouble. The live virus in the wood is not healthy. I kiln dry all my spalted lumber to kill the virus. I would suggest you do the same as well as for stopping the bugs and shrinkage issues.
6/17/13       #13: Spalted sycamore ...
Thank you all for your contributions to this topic. We have decided to withdraw all spalted woods from mantel options meanwhile. I will let our spalted timbers air dry for a year or two and then kiln dry. We will restrict the thickness to no just over two inches thick and will not use this type of wood for mantels in future for all the reasons highlighted!
6/19/13       #14: Spalted sycamore ...
Rich
bob,
spalting is caused by a fungus, not a virus. We are constantly exposed to these fungi in the forests as we walk through them. The question of health is heavily debated, but it seems there is no definitive testing to show any health problems associated with these varieties of mold spores.
6/19/13       #15: Spalted sycamore ...
bob
You are right Rich. A fungus. My mistake.
6/23/13       #16: Spalted sycamore ...
Tennessee Tim
James, from all my reading and studies spalting doesn't stop until under 20% MC. 2nd... just because you pull the spalted off the market till later, ANYTHING green and sealed with moisture are subject to fungus and mold....there are some finishes that "breathe" but I don't know if they breathe enough to release the moisture BUT then logs in log homes have a high MC and are usually way over 20% and I'm not seeing the mold or fungus growing under the finish unless there's another water issue. I'm not a finish knowledged person to address the correct finish. Many yrs ago some exterior repellents WERE causing a mold/fungus growth but I think they found it to be parafin related.
For your business's integrity, please read all the info and check up on answers given yourself and decide what's best for you and your business.
Have a Blessed evening in Jesus's Awesome Love,
Tim
7/13/13       #17: Spalted sycamore ...
Chris
Did thomebody thay thpaled Thycamore?
