Furniture Making
Subject: Re: Laminating Solid Wood Panels
8/9/13
Carlos Levine  Member
Hi, Can I laminate with HPL solid wood panels???, I have a lot of wood left over and gluing it up with my clamp carrier to make panels, since the panels are made from rejected wood from our production, I was thinking to laminate it and edge band, my concern is wood movement, or the laminated prevents change in humidity in the wood?
8/13/13       #2: Laminating Solid Wood Panels ...
rich
first thought is no, but maybe you could get a way with it if all the wood is laid up so only quarter sawn grain can be seen on the face. All growth rings would need to be perpendicular to the face. Then the greatest expansion will make the panel get thicker. May make edge banding a problem then. Solid core plywood used to be make like that.
