Furniture Making
Subject: Re: Ultralight MDF
Ultralight MDF
1/9/14
Tim  Member
Website: eastmanwoodworking.com
I am building an extension table for a customer, 4 legs, 42" X 48". The top will be veneered and I prefer to use MDF for its stability. The customer is concerned about weight; the leaves will be 18" X 42". I may use Ultralight MDF to keep the weight down, although it would only save around 3 lbs. on the leaves, 13lbs. vs. 16 lbs. Darryl at Vacuum Pressing Systems tells me Ultralight is very porous and that is needs to be sealed or sized prior to veneering. Aside from that I am looking for any other areas of concern about Ultralight. I would edge it with hardwood before veneering.
1/9/14       #2: Ultralight MDF ...
mark
Trupan ultralight is a good product. Glue sizing suggests that you're using a water-based glue; not sure I'd do that with ultralight. Unibond, without any special prep would be my choice.
1/9/14       #3: Ultralight MDF ...
Tim  Member
Mark:
Thanks for your reply. I use Unibond from Vacuum Pressing Systems. Darryl advised me to seal up the MDF as he had heard of problems. I will try samples both ways. Aside from that you have been happy with Trupan.
1/10/14       #4: Ultralight MDF ...
mark
Sure. I have to say that I don't like MDF for tables in general, and especially those with leaves, but I understand the decision. I've used Trupan for cabinet doors, prebanded with solid, then veneered like you are proposing for the table. Panel clean, Unibond, vac press, no presealing: no problems.
1/10/14       #5: Ultralight MDF ...
Tim  Member
Mark:
I don't necessarily like MDF either, but plywood is such a crapshoot and one does not know how it will behave until it is cut up. Not sure that 2 ply veneer faces on V/C with a Unibond glue line will flatten out any twist.
