Furniture Making
Subject: Re: band saw
band saw
3/12/14
Bob Edwards Member
Are there any band saw experts out there? My 14" ridged bank saw and a lot of vibration, any ideas?
3/12/14       #2: band saw ...
Fonkee
If it has ridges then that would be a good place to start - remove them and it should run more smoothly.
3/12/14       #3: band saw ...
Keith Newton
Bob, Clean everything, so make sure something isn't stuck on a wheel. Then start using the process of elimination.
Take the blade off, and run it with just the bottom wheel spinning. If it isn't down there, it must be the top wheel.
If the tires are glue-on, they can start to delaminate, showing a lump or bump while spinning.
Make sure it isn't the belt, or loose set screws. I've had the pulley shed a section that caused vibration.
With the belt off, turn the motor on to test it alone. you can spin the wheels by hand, and feel for slack, on all axis.
You didn't mention the frequency of the vibration. Motor will be faster than the wheels, which would be faster than the blade times around.
Do you have bearings on the guides?
3/12/14       #4: band saw ...
Rich C.
Easiest solution is to invest in a machine that would be considered a heavy professional bandsaw. This is being used in a professional cabinet shop right? Vibration comes from a rotating mass. Check the motor running with the belt off, then just the lower wheel, then the whole system. That will isolate which piece is the culprit. On a lightweight homeowner machine like this one, even the v belt can cause trouble.
