Furniture Making
Subject: Re: Base size
Base size
3/23/16
Tom Member
Greetings,
I researched here and found the 50% rule seems to be accepted as a reasonable standard for base size to top size. What do you think for an elliptical top? If I use 50% of the widest it kind of crowds the narrow ends of the top. Thanks for any comments.
ELLIPSE_TOP.pdf
3/24/16       #2: Base size ...
D Brown
To my eye the base's looks to large for the top size and a bit too close to each end for knees and such .
3/24/16       #3: Base size ...
Keith Newton
Another constraint that you might try to consider, is to provide about 12" of knee space for each place setting.
3/24/16       #4: Base size ...
Tom Member
Thanks for comments but I am mostly asking about the actual footprint of the base. Even if I skinny up the middle of the turning I still am looking at a fairly large base to make 50% of the wide width of the top. How does that relate to the narrow ends of an ellipse?
3/24/16       #5: Base size ...
Common sense can apply. If you don't like the answers you are getting, ignore them.
Where your pedestals are located, only about 6" (2 x 6") of the top overhangs the 19" base. That would call for a 12" base. In other words, determine what the width of the top will be at the pedestals (centerline), and apply the 'rule' there.
You also need to look at the whole with a critical eye and apply good proportions to the piece. Form AND function, within the context of good proportions. It is not just about a vague rule for base sizes. If you are unsure, look for precedent in historical context. What has gone before and is considered good design.
3/24/16       #6: Base size ...
Tom Member
Thanks David,
I was originally thinking on that line but started second guessing myself as to the wider part. I am no designer, and was looking here for some precedent from those that are.
3/29/16       #7: Base size ...
Artisan Millshop
Website: http://Artisanmillshop.com
A recent table project from the shop spans 182" when expanded, on a 60" (major axis) base, and is very stable (which surprised all of us).
We generally design for 14 inches clear from edge to any obstacle for seating, but pushed it on this one.
