Furniture Making
Subject: Re: Walnut slab color
Walnut slab color
6/28/16
Garen
Hello, I bought two walnut slabs from a local guy that cuts trees localy. I did notice when i bought them they had a little red tone to it. I finished the bottom of the slab. The table has a good red tone to it. Is this common or do I have an issue? All the walnut projects i have done always has a brown tone and some sap wood. I attached a picture. The finish is still wet.
View higher quality, full size image (747 X 1328)
6/28/16       #2: Walnut slab color ...
Rick W
Walnut can indeed have a reddish tone to it. I think it depends on the locality where it was grown. I bought some reddish walnut once that was cut in Nebraska and was air-dried.
I think that most kiln-dried walnut is also steamed, which contributes to the brownish tone of most walnut.
Rick W
6/28/16       #3: Walnut slab color ...
I've even seen purple tones. No two trees are the same.
6/28/16       #4: Walnut slab color ...
Keith Newton
Larger commercial mills will steam their Walnut to darken the sapwood. This renders the heartwood that gray color.
After about a year however, your air-dried walnut and the steamed > KD will all lighten and look the same color. Thus all walnut needs to be stained to bring up the small open pores, and to retain the nice dark richness.
6/29/16       #5: Walnut slab color ...
peTe Anderson
Website: http://petesfloors.wordpress.com
Walnut colored stain will help protect the color from changing in light over time.
6/29/16       #6: Walnut slab color ...
Garen
Would a good vinyl sealer and uv top coat acceptabl? Customer wants the natural look.
