Furniture Making
Subject: Re: Porter Cable Dovetail Omni Jig
8/24/16
ATS
Is it possible to dovetail drawer parts with the omni jig that are NOT whole numbered dimensions?
No problem with , say, 4", 5", or 9" tall (wide) box parts, but if for some reason I wanted to make a box that was 5 1/4" or 7 3/4' tall -- I can't quite seem to figure that out with this fairly complicated jig system. I'm probably missing something very obvious , or I'm just not smart enough to figure this out. Help?
8/25/16       #2: Porter Cable Dovetail Omni Jig ...
You can make the drawer dimension anything you want if you don't mind a little imbalance in appearance. I guess you are using the stock comb on it? I put the top of the drawer parts against the stop so their is a full cut. I then let it run out at the bottom of the drawer to whatever it happens to be. If you want it to have symmetrical 1/2 blind dovetails, you'll need another fixture with adjustability.
8/26/16       #3: Porter Cable Dovetail Omni Jig ...
Rick Garner Member
Website: http://rickgarnerfurniture.com
Hey the Omni jig is a nightmare...I know from experience...ugh ..bought a Keller jig not perfect, but a big step up.
8/26/16       #4: Porter Cable Dovetail Omni Jig ...
Rick W
You can use the dovetail jig to make any width drawer you want. You just have to set it up differently.
First,set it up like you normally would, using the stops. Then measure the offset of the pieces and set a combination square to that offset. Un-clamp your pieces and then center the top piece(the front/back of the drawer) on the comb with equal spaces on either side. Make sure it's square with the front of the jig.Then offset your vertical piece (the side) using the offset measurement on the square. Clamp the pieces down and rout the dovetails. Do the same thing but set the offset to the opposite side for the other side.
If you have a lot of the same size drawers, you can make a stop that locates the front/back piece on the jig and continue to set the offset of the sides with the square.
Basically, what you're doing is centering the front/back piece on the comb and offsetting the sides to it.That way, you get dovetails centered on the piece regardless of the width.
I've used this technique several times. I didn't originate it. One of the guys I worked with came up with it, and I quickly adopted it myself.
Rick W
8/26/16       #5: Porter Cable Dovetail Omni Jig ...
ATS
The problem with letting it be asymmetrical is there tends to be a gap at the top of the drawer for half blind dt joints which then needs to be filled. It's way less than ideal.
I agree this jig is sort of a nightmare.
Had to get on here because we bought it used with no instruction manual.
8/27/16       #6: Porter Cable Dovetail Omni Jig ...
ATS
Rick W, thanks for the tip. I'll definitely try that and let you know how it shakes out.
8/27/16       #7: Porter Cable Dovetail Omni Jig ...
Depends on how many you are doing, but why not make them an inch wider than you need, then rip them down with the dovetails centered. Might even be faster than resetting the stops.
