Furniture Making
Subject: Re: Drum Sander Conveyor Belt
8/25/16
Howard Gorman Member
I have the General 24" duak drum sander. Lately the conveyor belt moves in a jerky or stop/start manner. Sometimes I'll turn on the power on the belt doesn't move at all, then after a minute or two it starts to move. Not sure where to look first to solve the problem. I am a much better woodworker than I am at machine maintenance. Any suggestions for where to start to fix this would be greatly appreciated. Thanks.
8/25/16       #2: Drum Sander Conveyor Belt ...
Start with the switch, move to the motor. Also make sure all set screws are tight on the motors and pulleys.
8/26/16       #3: Drum Sander Conveyor Belt ...
Charles Member
I agree. Start with the switch. You might try spraying the guts of the switch with an electronics cleaner. (Disconnect from power supply first.) It might simply be dirt or corrosion built up on the switch contacts. Spray liberally, then let the switch dry real well before reapplying power.
CRC QD Electronic Cleaner is one that comes to mind. Walmart, Amazon, and Home Depot carry it. You should be able to find something similar at an auto parts store.
8/26/16       #4: Drum Sander Conveyor Belt ...
doug mclaren  Member
had same problem with my grizz. it was very regular with rotation of tension/tracking rollers. i adjusted tension on my rollers to keep belt from slipping
10/6/17       #5: Drum Sander Conveyor Belt ...
Alex Jordan Member
Website: http://jordanwoodworking.com
I have this sander and have had this problem. It's most likely the knuckle joint between the conveyor motor and the conveyor pulley. There's a little black box between the two that houses the joint. They get worn and slip. Called General International for a replacement and they were 6-8 weeks out, so I took a grinder and file to make the edges square, then backed it up with a few washers so they wouldn't slip apart. Viola! Presto, we're good to go. I have pictures of the process. If I can find them I'll post them.
