Furniture Making
Subject: Re: Prefinish Or Not To Prefinish
11/4/16
Tom Member
I am in the process of making a Stickley inspired bed frame. The head and footboards have arched top and bottom rails mortise and tennoned to legs. The rails also have 7 evenly spaced slats connecting them with mortise and tennon joints.
I plan on finishing them to match a pair of night stands that I made. This was a multi-step process, that involved water based dye followed by a sealer, gel stain, and finally a top coat.
From my experience finishing the night stands, it seems like it would be easier to prefinish all the parts before glue up.
Is there any downside to prefinishing, or reason I shouldn't consider it? Also, are there any tips or techniques I should be aware of to be successful with the outcome?
Thanks for the help,
Tom
11/11/16       #3: Prefinish Or Not To Prefinish ...
Societal
Do you mean "Apply finish prior to assembly"? If so, I would suggest that is a good idea. It is, however, merely finishing, not pre-finishing.
11/11/16       #4: Prefinish Or Not To Prefinish ...
Tom
Yes, I guess I shouldn't have said pre-finish. I did imply finish pre-assembly, or glue-up.
11/24/16       #5: Prefinish Or Not To Prefinish ...
Bill  Member
Website: canadianacabinets.com
We finish most everything before assembly
Just be sure to mask off mortises and tenons or dowels and use clamping caulks with smooth faces..
Cheers
