Furniture Making
Subject: Re: Pm shapers and feeders
5/19/17
I'm looking at buying a Powermatic 2700 Shaper and I'm looking for opinions of which one to buy and why:
The 3HP 1PH 230 v
5HP 3HP 230v
Or
5hp 3HP 230/460
And which auto feeder
pf3-jr feeder 1/4 hp 1ph 115 v
Pf-31 feeder 1hp 1 ph 115 4 speed
Pf-33 feeder 1hp 3hp 230v 4 speed or
Pf-33 feeder 1hp 3ph 460 v 4 speed
And why?
Thx!!
5/20/17       #2: Pm shapers and feeders ...
You are asking if you should be a smaller single phase motor, or a bigger 3 phase motor? Go with the bigger 3 phase of course. No start capacitors to fail latter in life, and higher HP for the obvious reason. I assume you have 3 phase since you ask.
5/20/17       #3: Pm shapers and feeders ...
Yes I have 3Ph.
5/20/17       #4: Pm shapers and feeders ...
Aside the power part, is one "better" than the other for both the shaper and the feeder ?
5/20/17       #5: Pm shapers and feeders ...
We have a 1HP PM 3 wheel feeder in the shop. 2 speed (4 with a drive sprocket change).
My advise would be #1 not to spend the money on the PM in the first place. I dont think they (in the case of the PM27xx) are worth the extra price for the gold paint if your buying new. But if your set on PM and New, 5HP on the shaper minimum if its going to be your main machine. Used shapers dont come around to often but you can often find nice used industrial machines at a much better price and you'll have a much higher quality shaper in the end.
For the feeder, I cant tell you how many times I wished this feeder was a 4 wheel which we have elsewhere. In the feeder I again would opt away from the PM and go with one of the new Comatic DC40's or something similar http://www.co-matic.com/en/product/PF-DC40 Much better all around for similar money.
Just my 0.02
5/20/17       #6: Pm shapers and feeders ...
https://youtu.be/WtXJk6bQk0o
5/20/17       #7: Pm shapers and feeders ...
I had a 1995 PM27 shaper that had a spindle carrier that was hanging on off centered sliding dovetail ways. This thing wore out in no time and it took huge efforts to get it all out and re-machine the ways. Then 3 yrs later, it was all loose again.
SCM has a much better way of holding the quills. I suspect the better PM's also have this sleeve arraignment.
I don't know who is making PM now, but I would think about older Italian or similar.
I do have a 1980's 18" PM planer that is just about perfect. Very good machines, worth restoring and using everyday.
5/21/17       #8: Pm shapers and feeders ...
door shop guy
I have 4 of the Powermatic 2700 shapers all 5hp 1ph. I also have a new Casadei F200 Itialian shaper. Yes the Casadis is heavier and better built but with much more electronics and i had a problem with it right out of the crate that i had to pay an electrician to troubleshoot and SCM/Casadei drug that out for months adn they acted like they did not even know what i was talking about. Suprisingly the Casadei is the only shaper that bogs down on raised panels and i have the speeds and feed speeds set the same as my other 2700 PM raised panel shaper. There are a couple things i like about the Casadei over the Powermatics but not enough for it to be my favorite. Overall the Powermatics are more user friendly with easier to use more precise fences. The caster system on the Powermatics is no joke. I have had my Powermatics much longer than my Casadei and had to replace bearings once and that was only $250 had the part at my door that week and only 20 minuites to replace. My shapers are dedicated and get used hard every day. Now...the digital readout on the 2700 shapers is a gimmick that i never use. Get Steff feeders from J&G machinery and get the powermatic shaper and you wont have to go thru a company who hired one of the worst guys (who used to sell Steff) in the industry who lied to and ripped/tried to ripoff off many people including myself.
Whoever compared the 2700 to the older model PM shaper is comparing apples to oranges i know i had an older PM shaper and got rid of it long ago.
5/22/17       #9: Pm shapers and feeders ...
I have to agree that I would buy a used SCM over a PW all day every day. We have replaced the quill on the powermatic and then had to replace bearings on the new quill. It is not a heavy machine at all.
We have other european shapers in the shop and there is no comparison in their construction.
Check the auction sites and find one with a good fence system.
5/22/17       #10: Pm shapers and feeders ...
Not sure if this link will work but this will likely go for less than the PM. Look at the quill photo.
Shaper
7/20/17       #11: Pm shapers and feeders ...
Skip the PM and buy something better. Comatic feeds are OK, get a 4 wheel, 3 phase. Put urethane tires on it.
Used Italian shapers, 3 phase 5HP or greater. I had a PM shaper that I got new, sold it to a fool. Got a used Gomad tilt, great machine.
I'm just not a fan of Chinese tools (PM) if you want them, get some other brand and pay a lot less for the same thing (different color.)
