Furniture Making
Cherry Mantel
3/1/13
Chris
I have a cherry mantel to build and I am planning on making the top out of a double layer of 13/16 cherry with a piece of cherry turned up side ways to cover the front and the ends do you see any problem with this I did a Walnut one 5 yrs. ago and it has done fine . Thanks
3/2/13       #2: Cherry Mantel ...
JeffD
Seems like it would be a whole lot easier to start with a thicker piece of cherry rather than go through all that trouble to make it look thicker no?
JeffD
3/2/13       #3: Cherry Mantel ...
Chris
Well it would seem that way but the lumber yard I get it from is 40 miles away and I hate to go after just one piece of lumber I don't usually keep any around this thick Thanks.
3/5/13       #4: Cherry Mantel ...
Jon
The pieces added to the ends won't fare well over the long term if you simply glue them on. Either breadboard them or use nails and expect some movement. Otherwise, it's fine.
