Furniture Making
wood movement in 55" dia table top
1/26/14
gunnd Member
I'm building a table out of 6/4 walnut or cherry (customer hasn't decided on species). The top will be 55" diameter, 1-1/4" thick. Boards will be approx. 9" in width. In the center of the top, a 12" x 12" section of handmade tiles will be set into the top (a hole a bit bigger than 12" x 12" will be cut through the top; 1/2" plywood under 1/2" cement board will be supported by brackets with slotted screws on the bottom; flexible, sanded caulk will fill the grout space around the perimeter of the tiles, which will be grouted with acrylic-based grout in the central grout spaces. this will allow the wood to move without cracking grout.). I'm trying to decide whether to put a dry spline along the center-line of the wood top to accommodate wood movement. The spline would be 3/8" thick; an opening of 1/4" would be incorporated as a design feature. 1-1/4" by 2-1/2" battens on slotted screws will run across the grain under the top. I'd rather not do this; I don't like the 1/4" groove along the center line of the table. Will wood movement require such a dry joint? I've done smaller tops like this with no dry joint.
1/27/14       #2: wood movement in 55" dia table ...
If you think about the solid wood moving in width from any point, then you will see that a center split/spline is unnecessary.
If you think of a point at the center of the top, then you will have 27-1/2" of wood moving away from or toward that center point. But the center point doesn't move.
As long as your table support structure underneath allows for expansion and contraction, you should have no problems. The 12" hole will benefit from allowed movement, but it will be much less than the whole of the top, of course.
The Shrinkulator can help you anticipate movement amounts.
The Shrinkulator
2/15/14       #3: wood movement in 55" dia table ...
Gene Wengert-WoodDoc
Although David did not mention it is his reply, a key for you will be to get the initial MC of the wood equal to the MC that the table will have in use. This will minimize any movement. You probably want to have all the wood at 6.75% to 7.0% MC. This is really a tight specification, but you are making a fairly large table.
2/21/14       #4: wood movement in 55" dia table ...
Doug Member
Thanks for the helpful thoughts re: wood movement.
The tile detail now requires an 18" by 18" cutout in the top.
I'm considering putting the tiles at 45 degrees to the grain direction, for aesthetic purposes, but also to better distribute the push and pull caused by wood movement. I'm thinking that the forces on the caulk surrounding the tiles would be more evenly distributed if obliquely against the caulk.
I'd be grateful for opinions about this.
2/26/14       #5: wood movement in 55" dia table ...
By going diagonal you just increased your likely movement in the tile area.
