Furniture Making
Mesquite tabletop question
4/22/14
Chris Member
Website: http://www.windsorcraftdesigns.com
Have a project for making a table top out of air dried mesquite. Since this top is to have wide mitered trim around all four sides, we've decided it best to laminate the mesquite to a stable core. What we're planning is to resaw the wood to 1/4" thick and glue it to both sides of a 3/4" core. The question is: what would you use as a core (substrate)?
4/22/14       #2: Mesquite tabletop question ...
Scott Sober  Member
Website: http://www.cymafurnituredesign.com
You are going to have to go thinner than 1/4", more like 1/8th" or a little lighter. 1/4" inch will act like a regular board for expansion and contraction. You can use MDF for the core, nice and flat, albeit a bit heavy.
4/24/14       #3: Mesquite tabletop question ...
CRIS
Call custom panels they will lay up mesquite on any substrate you prefer. I would recommend 3/4 M D F.Their # is 281-489-9000
4/24/14       #4: Mesquite tabletop question ...
mark
Don't do it unless you have a moisture meter... and know how to use it. Air dried does not mean "unstable", but it does generally mean that the material has a higher moisture content than indoor wood. It will shrink regardless of what you do to it (apart from drying it) when it goes inside. If you want to know what laminated 12% MC material looks like when it starts to dry, then go to the big box store and look at some sheathing ply.
4/25/14       #5: Mesquite tabletop question ...
Chris Member
Thanks guys for the advice. What I'm going to do is laminate the 1/4" slabs to both sides of 3/4" MDF, but thinning them down to <1/8" via the drum sander. I'll do one side at a time in order to have a flat face as a reference... What glue would you use?
4/25/14       #6: Mesquite tabletop question ...
Air dried may not mean 'unstable' but it does often mean 'not as stable as kiln dried'.
If you put 11% Mesquite onto 8% MDF, take pictures so we can see how it fails.
I would thickness the faces to 1/8" and then meter it and everything else. If the table faces are more than the MDF core or any other parts, there will be problems. It is not just a matter of gluing well or hoping for the best, it is just different moisture levels will move against each other.
