Furniture Making
keep live edge on slabwood
9/17/14
Brad Hopke  Member
I have a large slab of Ash. I would like to keep the live edge on it. Bark is on there securely right now. So removing it to glue it would be hard. Any ideas out there? I plan to do a light dye then a Conversion Varnish finish. Don't want to go the bar pour way.
9/17/14       #2: keep live edge on slabwood ...
If the bark made it through the kiln, it should be fine for a long time. Dye around the bark won't be easy unless you plan to dye it as well. I don't use heavy film finishes on slabs that have bark. I prefer oil and use compressed air to blow it off the bark instead of trying to wipe it off.
