ideas for tabletop with tiny lights shining through
12/9/14
a client is interested in a gloss black table top with little dots of light shining through. has anyone done something like this and is willing to share.
12/9/14 #2: ideas for tabletop with tiny lights ...
fiber optic strands, black plex, tiny drilled holes in substrate for each or small group of strands. You'll need to experiment with the plex & the optic fiber to get the intensity they are after.
12/10/14 #3: ideas for tabletop with tiny lights ...
thanks scott for the suggestions. if you have done this I would love to talk. my concerns are with the finish showing where the pin holes are located because it will be a high gloss finish and all defects will show.
12/14/14 #4: ideas for tabletop with tiny lights ...
Just a thought...fiber optic or LEDs under veneer. Drill tiny holes in substrate, then veneer. The light will shine through.
1/1/15 #5: ideas for tabletop with tiny lights ...
The idea you want to implement is a DIY work. If you are looking for gloss black table top, then I do believe that this amazing Magazine Coffee Table product at Zopalo.com will definitely attract you.
2/7/15 #6: ideas for tabletop with tiny lights ...
Well damn! As a cab and furniture maker,
"the cobbler has no shoes". My wife thanks you mason brown.
4/23/15 #7: ideas for tabletop with tiny lights ...
I would like to tell you that you can use customized sublimation. That will look great at table top.
View higher quality, full size image (920 X 400)
Custom sublimation
