Furniture Making
out door furnirure marine plywood
7/7/13
stephen Member
Any opinions about using marine plywood of Okume or Sapele to make unfinished outdoor benches?
Will plywood delaminate?
7/24/13       #2: out door furnirure marine plywood ...
Jim Baldwin  Member
Website: http://www.handrailer.com
Yes, left unsheathed, all plywood will fail PDQ. Exposed plywood is only recommended when clad with epoxy/mat coatings, as in boat building. Straight painted plywood is a mortal sin.
8/2/13       #3: out door furnirure marine plywood ...
mark
Marine plywood can be used painted or varnished on vertical or sloped surfaces (really sloped, like 15+ deg. off level) but never unfinished or unbanded. For horizontal, sheath with glass/epoxy, then paint or varnish for uv protection.
All marine ply is not made to the same standard, so be careful. BS1088 used to mean something, but is now defunct, so all cheap ply is sold as "meeting BS1088". Voids will cause trouble, as will thin exterior veneers, so buy from a reputable manufacturer that lists real material specifications on their website, and grade stamps their product edge.
As to the species that you are considering, neither would be recommended as weather or rot resistant enough for unfinished exterior service, solid or ply.
3/4/15       #4: out door furnirure marine plywood ...
markbattles Member
Website: http://v-dubfurniture.com
Marine playwood can be used painted or varnished on vertical or sloped surfaces .
    • CP Adhesives
    • Anver Corporation
