Furniture Making
holytek planer won't close
6/23/16
boxedj Member
We have a 43" planer/sander/sander from holytek, (very old) which ran fine until today.
I can adjust the bed to lower for a wider piece, either with the down button or by punching in the thickness numerically, but it will not close. If I type in a lower number or press "up" to raise the bed, it just sits there.
Anyone know if there is a safety switch on these old holy tek machines that might have tripped? Any info appreciated.
6/25/16       #2: holytek planer won't close ...
duster
I'm not familiar with your machine, but my sander does the same thing occasionally. Try manually pushing in the magnetic contactor for the elevation motor. Mine has one contactor for up and one for down. If it will go up by holding the contactor closed but not by the up button on the control panel, you may have tripped the reset switch. My contactors have a small plastic push/pull switch that is used to reset the contactor. I'd give that a try first.
6/27/16       #3: holytek planer won't close ...
Kevin Jenness
We had a similar problem at my old shop with a widebelt sander. The automatic thickness setting switch was stuck so the table would not rise ( the sensor that sets the table height based on contact with a workpiece sitting on the conveyor).
