Furniture Making
MDF Okay For Curved Table Apron?
10/16/17
Brian
Is it ok to use stacked and glued-up MDF rings for a round table apron that will be 22 inches diameter, 1-inch thick MDF ring, with a 2.75 inch wide apron face? 1/16 inch veneer would then be glued to the outside diameter of the ring.
I just read about this in Fine Woodworking, however the author used MDF as a template for a wooden ring; I have the MDF to make the rings but don’t have the wood to build a wooden ring so I’m wondering if there are issues with using MDF instead of wood.
The veneered face will be paint-grade poplar, and the table legs will also be poplar.
10/16/17       #2: MDF Okay For Curved Table Apron? ...
The bottom and back faces of the MDF ring are going to be left raw? And if its paint grade why apply the poplar veneer in the first place?
10/17/17       #3: MDF Okay For Curved Table Apron? ...
duster
I've done many curved aprons using mdf for the laminates with good success. I use 1/4" for large diameter aprons, like 54" plus. For smaller diameter ones, I use 1/8", which will bend much easier. I build up to a 1" thickness and normally use a wood veneer on the face to match the top and/or legs. If I was painting it, I don't think I'd bother. I did the table in the photo with this method.
10/17/17       #4: MDF Okay For Curved Table Apron? ...
duster
Here's the photo.
10/17/17       #5: MDF Okay For Curved Table Apron? ...
duster
For some reason, the photo will not post...
10/18/17       #6: MDF Okay For Curved Table Apron? ...
The Staff at WOODWEB Member
This is the image that Duster was trying to post -
View higher quality, full size image (600 X 299)
