Furniture Making
Drawer Question
12/19/18
Howard Member
Client has me building a bedroom set with veneered drawer fronts. I will use baltic birch and was going to use 7/16 maple for the sides and back. Half blind dovetail in front through dovetail in back. I didn't want to do an applied front since that doesn't look very professional. My question is would attaching a maple side to the baltic birch front cause a wood movement concern? The sides are 7 1/2 wide. THanks.
12/19/18       #2: Drawer Question ...
Matt Calnen
When doing furniture grade veneered drawer fronts like this, I like to use quartersawn hard Maple for everything. It’s very durable and wears well,has good stability, and you don’t have to use “sheet goods” in a fine piece of furniture which I hate.
12/19/18       #3: Drawer Question ...
John Member
You could use solid wood instead of BB to glue your veneer to and eliminate any potential issue with seasonal movement with the solid wood sides.
John
12/24/18       #4: Drawer Question ...
BH Davis  Member
I think you are correct to be concerned with wood movement here. The dovetails aren't going to give any room for the drawer side movement and splitting somewhere in the side panels is likely.
If you are set on the Baltic Birch/veneer fronts then you can go with a blind sliding dovetail when bringing the sides into the front and your regular through dovetails in the back corners. Not as traditional a construction but certainly professional.
2/20/19       #5: Drawer Question ...
cwwoodworking
In my retail days, I used to deal with a solid wood bedroom company.
They used a slide in dovetail plywood side into a solid wood drawer front.
Did this for over 40 years without an issue.
2/21/19       #6: Drawer Question ...
D Brown
Much of the older furniture with veneered drawer faces were on solid stock but they veneered the back as well for stability on many pieces. Instead of plywood showing.
