mitering radius molding to straight
1/22
Website: http://CARPENTRYASSOCIATES.COM
I recently had to mitre a straight crown to radiused crown of the same profile. After a lot of grief, we finally recognized that it is not a true miter but a miter similar to a rake. Anyone have any suggetions as to a quicker way to figure out the matching angles for this type of joint?
1/23 #3: mitering radius molding to straight ...
I have found it needs to be a curved cut.
This discussion may help
similiar problem
1/24 #4: mitering radius molding to straight ...
Website: http://www.handrailer.com
Here is Pat Gilberts' curved solution (straight out of a 100 year old book). The only difference is the projection lines of your crown molding will need to be drawn from a vertical perspective.
A bisected, straight/angle miter is only possible if you change the size and profile of the curved crown to match the straight cut.
I once worked an order for 1200 scalloped plant-on panel molding corner pieces. They were made to match the straight moldings which were all cut on 45 degree angles. The actual profile and width of the curved pieces had to be slightly different than the straight.
By doing it this way, the miter cuts on the curved pieces were also straight and parallel. A simple jig on the table saw was then used to pre-cut all the miters to perfection.
All of this falls under the heading of "enlarged or diminished moldings" to match straight or curved sections. This is a topic of various configurations and possibilities, including intersecting radii.
Old Gothic-ecclesiastical architecture is often full of these mind-blowing, perfectly matched and intersected moldings.
View higher quality, full size image (560 X 464)
View higher quality, full size image (1008 X 512)
1/29 #5: mitering radius molding to straight ...
Jim, could you let us know the title of this book, and possibly where you got it?
I am always looking for sources of old woodworking texts.
1/29 #6: mitering radius molding to straight ...
Modern Practical Joinery by George Ellis (1902)
3/7 #7: mitering radius molding to straight ...
If the moulding profile is narrow (say, less than 3") you can get away with a straight miter cut and a little hand sanding. For larger profiles the miter cut is indeed curved as shown above.
When a customer requests it I will draw the joint for them in AutoCAD and send them a printout along with their radius mouldings (this usually easily fits on an 8 1/2 x 11 sheet). They can then lay the print out on the backs of the mouldings and trace the cut. This still requires a higher than average skill level since you are cutting from the back but will give the correct cutting of the joint.
3/7 #8: mitering radius molding to straight ...
Why don't you cut the miter with the cnc?
Buy & Sell Exchanges | Forums | Other Resources | Site Map
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Project Gallery
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
