Subject: Re: 30,60,90 crown around a 3/4" bullnose
2/11/14
Hello all.
I'm looking to do crown around a typical bullnose 3/4" radius drwall corner.
Im trying to lay it out in autocad and the 30/60/90 rule isn't working out. I offset my two lines at 3", then drew lines from the center point of my radius out at 30/60/90 degrees and the corner crown piece needs to be wider in order to work. I was however able to lay it out using 22.5/67.50/112.50 angled lines and all outset lines at 3" each way works.
Is it just not fesible to do 30 degree angles around a 3/4" radius corners?
Thanks,
Stumped
2/12/14       #2: 30,60,90 crown around a 3/4" b ...
Chris
Seems like 30 60 90 would add up. In the field it's 22.5 22.5 and once more 22.5. Can't give you a CAD/geometry answer as I flunked per algebra 27 years ago.
2/12/14       #3: 30,60,90 crown around a 3/4" b ...
Thanks for the thoughts. Lol. Im right there with u on the math.
2/15/14       #4: 30,60,90 crown around a 3/4" b ...
mastercabman
Are you trying to make a corner(90*) out of 3 pieces?
If so 22.5* is what you have to use
There will be 4 cuts,each at 22.5* = 90*
So I don't know where you are getting 30*
2/15/14       #5: 30,60,90 crown around a 3/4" b ...
Because my dumb logic told me 30/60/90 in 3 cuts could make it around a 3/4" bullnose outside corner
2/20/14       #6: 30,60,90 crown around a 3/4" b ...
brian
nope 22.5 the middle piece is usually about 5/8" on the short:)
2/22/14       #7: 30,60,90 crown around a 3/4" b ...
Mark
Is the bullnose 3/4" radius= 1-1/2" diameter or 3/8" radius= 3/4" diameter".
If the latter, just 45 mitre the crown at the intersection of the wall planes and cope in a small filler block around the corner. Cleaner look IMO. Another way is too cut the corner bead out at the depth of the crown and put in a square block to mitre around. It can be done around the larger radius too, but usually some type of finial has to be used.
I hate bullnosed corners. Makes any type of base, chair rail, crown, problematic.
2/23/14       #8: 30,60,90 crown around a 3/4" b ...
Leo G  Member
Website: http://www.lrgwood.com
Couple of ways.
View larger image
