Subject: Re: counter top divider
counter top divider
11/23/14
any good ideas Member
Does any one have any good ideas on how to attach a divider to the floor and wall above the counter top with out seeing the attachment hardware. I can use a metal angle under the counter top, but the divider will still move and flex at the floor and at the top.
CTOP_AND_DIVIDER.pdf
11/23/14       #2: counter top divider ...
nicko
for fridge end panels i have screwed a lag bolt into the floor and then cut the head off.
then drill a hole in the bottom of the panel corresponding with the cut off lag bolt and set the panel on it. not sure if that helps but good luck..................nicko
11/24/14       #3: counter top divider ...
Thank you, I'll have to try that.
11/24/14       #4: counter top divider ...
Nicko
I have also gone to the basement and ran a screw up through the floor into the bottom of the panel.
The lag bolt trick doesn't work if your panel isn't thick
Nicko
2/23/15       #5: counter top divider ...
I like to run a 1/4" wide dado top & bottom, tall enough to be able to scribe the divider, then attach a piece of 1/4 x 1/4 to the floor or top, and slide it in place from the front. Cheap, easy, invisible.
3/6/15       #6: counter top divider ...
any good ideas
Thank you Bill
