Subject: Re: Crown molding glue or no glue
5/18/15
Bob Member
For the last 30 years I have been using glue along with pins to put up crown. A little dab every 8" or so. Wondering how many others do the same and whether its necessary.
5/18/15       #2: Crown molding glue or no glue ...
JeffD
If we're talking about larger crown up to the ceiling I use liquid nails with a finish nailer. Smaller crown going to cabinetry I usually don't glue since it's all pre-finished.
JeffD
6/3/15       #3: Crown molding glue or no glue ...
Do you mean 23 gauge pins or 18 gauge brads?
Like JeffD said if its finished not much point in glue and it makes a mess.
Many guys use a Grex style 23 gauge pinner with lots of pins. No glue required.
6/25/15       #4: Crown molding glue or no glue ...
Chris
Small crown (prefin or not) I use fastcap 2p10 with accelerator. For the tops of cabs, I build a "snake" that mocks the perimeter of the cabs and set the whole kitten kaboodle as a unit. I've done tests with tHis this stuff ( very scientific).. Take 2 pieces of mdf...glue with accelerator, wait a minute and throw it on the concrete floor as hard as you can (didn't come apart but the mdf itself split) for big crown I use yellow glue and spring clamps. I also use construction adhesive on the backs of the miter as extra assurance. No nails hardly ever.
1/3/16       #5: Crown molding glue or no glue ...
JBDyer Member
I glue the ends only and use a 3/4" x 18 ga. pin. The 23 ga pin is not a good choice for this application, the pin does not have a head and will not hold the crown if it gets a little bump in the future. If it works for you then keep doing what you are doing. I wouldn't do it your way strickly because I install non finished raw stain grade cabs and do not want any glue to dribble down the face frame causing a spot that will not take stain. If your system works for you then keep at it. JB
