Subject: Re: faux beam installation
5/21/15
Henk Cusveller Member
Website: http://thecabinetmaker@thecabinetmaker.ie
Hi, I'm referring to the post in this forum:No-Seam Faux Ceiling Beams
Advice on how to build and install fake ceiling beams with invisible seams. October 14, 2009 - See more at: http://www.woodweb.com/knowledge_base/NoSeam_Faux_Ceiling_Beams.html#quest
Cust
omer wants hollow, or faux beams installed. Existing ceiling is timber joists and plasterboard. My idea is to fix a 'nailer', I mean a piece of timber directly to the plasterboard. The hollow beam, U-shaped will slot over the nailer and nailed from the side. My problem is how to fix that 'nailer', or bottom plate to the plasterboard. As always, the joists are not where we want them. Any special fasteners and is that strong enough. Don't really want to remove plaster board and nail blocking between joists. Beam made of 12mm MDF, to make it as light as possible. Comments and ideas welcome. Hopefully I've explained what the idea is. Thanks so very much. Henk Cusveller, Galway,Ireland
5/21/15       #2: faux beam installation ...
12mm MDF is the lightest material you can use? I'd suggest a lot of 12mm hardwoods will be lighter. Construction adhesive and toggle bolts would be my method to attach the nailers
6/2/15       #3: faux beam installation ...
DJW
You could also cut a slot behind where your backer is going so that you can slid a 2x4 into the ceiling and then turn it crosswise. It will help spread the load out behind sheetrock\plaster.
7/8/15       #4: faux beam installation ...
Dear Rich C. Your suggestion about weight was a 'lightbulbsituation'. I constructed the beams from building grade 18mm pine. Planed. Very light, easy to fill and sand. Toggles worked well too. I was very lucky that the electrician had opened the ceiling to see where wires and timbers were. Appeared that joist ran crosswise, so I could screw the base plate directly into them. Phew. All turned out well. Happy customer. Thanks for input. Cheers Henk
7/8/15       #5: faux beam installation ...
Dear DJW. Thank you for response. That would have worked, yes. In fact had to do something similar where a steel beam got in the way.
Result turned out well. Beams cost me a lot of sleep and as usual I needn't have worried so much.Happy customer. Cheers Henk
View higher quality, full size image (3648 X 2736)
7/9/15       #6: faux beam installation ...
Glad it worked out!
7/10/15       #7: faux beam installation ...
nicko
why did you put an end cap on the beam?
you should have stacked end grain pieces and glued them together then mitered it into the end of the beam. Then it would look like a real beam with end grain
nicko
7/10/15       #8: faux beam installation ...
Re: end cap. All painted white. Filled, sanded, caulked, primed, caulked.
7/10/15       #9: faux beam installation ...
nicko
sorry for jumping to conclusions Henk.
it is beautiful
nicko
