Subject: Re: Shopping for a new Laser Level
5/26/15
Chris Gray  Member
Website: bluehillwoodshop.com
We're in the market for a new laser level, we've been using a $200.00 dewalt , Horz. and Vert. Line 180 deg., and we have a couple of the Bosch horz. and Vert. dot, both a handy.
I've seen the Robo levels, and seen plenty of contractors with $1500.00 stabilas, that shoot a 3/8 thick line 360 deg. But thats not for us.
We're looking for a good all around Laser level for cabinet installs, Any thoughts on brands we may not be aware of $? what do you use $? Thanks
5/27/15       #3: Shopping for a new Laser Level ...
Nick
Hey Chris, I've used the ones you mentioned, I didn't mind the dewalt, but you can do better.
I've been using the PLS 180's for over 5 years (I'd probably still be on my first one if everyone else didn't like them as much as me)
The line is at least a 1/4 of the size of the dewalt, the horizontal shoots right around 180 degrees, and the vertical actually shoots behind itself (you can put it on the floor with the back against a wall and you'll see the line start about a foot up)
Plus the price is right +\- $300.
5/29/15       #4: Shopping for a new Laser Level ...
Gerry
We have been very happy with our Bosch GLL2-80 It has 360 degree line both vertical and horizontal. It has a pendulum lock and we are careful to use it when transporting. They have a GLL3-80 version out now so that may be worth a look. Has been plenty accurate for us working to the middle of the line at all times.
Gerry
5/30/15       #5: Shopping for a new Laser Level ...
Joseph D. Christman  Member
Website: IntegrityDesignBuild.com
Thumbs up for PLS - good quality, great service, and made in USA.
I recently moved up to their new HVL 100
The three lines are invaluable for complex layouts where everything has to be square and aligned with existing points (lights, openings, etc.) Unlike the GLL3, this PLS laser will rotate on its base (including a micro adjust knob) to hit hero points and project a plumb dot down for your base point.
http://plslaser.com/products/pls-hvl-100
5/30/15       #6: Shopping for a new Laser Level ...
Chris Gray
Thanks, I was looking at the PLS online, But I've never seen one on the job site
Are any of you familiar with the Leica Lino L2?
5/30/15       #7: Shopping for a new Laser Level ...
Gerry
Chris said "We're looking for a good all around Laser level for cabinet installs"
For me that is the Bosch. The PLS HVL 100 is bigger heavier and more expensive than the Bosch. My Bosch came with a base that has height adjustment and allows the laser to swivel. I also have the receiver that allows it to be used out to 265 feet.
I am not selling anything just saying for cabinet and other millwork installs I am happy with the Bosch
FWIW
Gerry
5/30/15       #8: Shopping for a new Laser Level ...
Cabmaker
We have a Hilti laser level that does a great job of on walls. It will produce a vertical & horizontal line that's pretty easy to read even with a lot of ambient light.
It will also produce a criss-cross pattern on the wall showing horizontal at 90º to the vertical line.
I would like to be able to show a 90º criss cross on the floor. I think this would be the best way to establish how square a building is when laying out cabinets. We can do this with our Hilti but the light keeps blinking when we do.
Does anybody know of a laser level that can produce a criss-cross pattern on the floor?
7/21/15       #9: Shopping for a new Laser Level ...
Richard Member
I've been using the Bosch GLL 3-80 P Professional. Very happy with it.
