Subject: Re: Placement of stay for tilt out hamper hardware
9/7/15
I'm trying to find the right placement for the arm that attaches to the back side of the door that holds the door with the basket attached. See pic.
I found the instructions on Rocklers web site but it's not specifically for tilt out hampers. It's more for a tilt down face with flap hinges.
These doors are half overlay and bottom hinged. I followed the instructions in regard to how far off the bottom inside fixed shelf, which means wirh a 32 mm system, there are 3 exposed holes. IF that is correct, I can't seem to figure out where th arm should be on the vertical pole and at the same time how far up the 3 hole bracket should be mounted on the backside of the door, along with how far in the bracket should sit in from the edge of the door
Anyone?
2/1/21       #2: Placement of stay for tilt out hamp ...
Matt Member
Did you find an answer to this? I'm trying to build a cabinet for Hafele's Flap Stay Hamper kit and looking to find the optimum cabinet (Carcass) width and depth.
