Subject: Re: 90 degree soft close lid support for 80lb lid?
6/4/16
Tom Member
I bought a very large chest made of teak and mounted a 50" LED TV to the inside of the lid so we could hide the it when it wasn't in use. The lid (with the tv mounted) is about 80 lbs and 24" from hinge to lip. I want something that keeps the lid open at 90 degrees and keeps the lid from slamming when it closes. The best thing I've found are a pair of these Stabilus gas springs (http://truck-hardware.orrorr.com/item/refrigerators/ll-categories-gas-springs-gas
-springs-for-cabinets/8031uw?) but they can only handle 56lbs. Is there a better product for this application?
6/6/16       #3: 90 degree soft close lid support fo ...
Rick W
You can get gas springs in a huge variety of sizes and supporting weights from McMaster-Carr and others. There are many sources for them.
Check to make sure that you have enough room for to fit them in the cabinet in the right position so that they help lift as well as support the lid.
Rick W
