Subject: Re: Best wood for shower
1/17/17
dan nelson Member
We would like to do a barrel vault in a shower. walls are 9' ceiling is 10'. Does anyone have a suggestion on the best wood to use for the ceiling? We would be milling in our own T&G. Teak and mahogany are a no go . We would surely be sealing the daylights out of it with conversion varnish, lacquer or poly. Fastening with exposed stainless screws and trim washers to wood substructure. Thanks Dan
1/17/17       #3: Best wood for shower ...
D Brown
You could use Redwood .
1/17/17       #4: Best wood for shower ...
doug mclaren  Member
why are mahogany and teak a no go. just curious. I've never seen wood hold up long term in that situation.
1/17/17       #5: Best wood for shower ...
dan nelson Member
teak and mahogany- cost are the primary factor. might have to go with a tile plank. Client really wants to see the fasteners for the look their going for
1/18/17       #6: Best wood for shower ...
My first response would be the new ceramic flooring that looks like wood. My second option would be rift sawn white oak. If you use flat sawn, it's going to move a ton with those kind of moisture swings! Talk to some wood boat guys, ask them if they would use wood in a shower. They'd tell you sure, as long as you sand and refinish every other year!
1/18/17       #7: Best wood for shower ...
doug mclaren  Member
White oak will turn black as soon as the moisture gets to it. Saturated with epoxy maybe
1/18/17       #8: Best wood for shower ...
Matt Calnen
If there not high end clients, why not just use axel?
1/19/17       #9: Best wood for shower ...
Ipe
1/20/17       #10: Best wood for shower ...
EDWARD KITSON
Matt,
What is "axel" .have never heard of this type of wood. Googel gives me everything but a wood.
1/20/17       #11: Best wood for shower ...
John Member
I'll second Ipe'. It lasts for 50 years or longer outside and is pretty easy to clean and keep looking good. Just make sure it's dry before using it. What you buy for decks is only partially air dried, and it shrinks a lot more until it's finally dry. Get KD if you can; otherwise, it will take many weeks to dry to the point you can use it.
John
1/25/17       #12: Best wood for shower ...
Kevin Member
Website: http://bayerleinenterprise.com
Ipe as well, we have done shower floors (elevated) with great success, it's a VERY hardwood and extremely tight grained
