2 vs 4 leg levelers
10/25
There appears to be two schools of thought on levelers: use 4 of them for each cabinet or use 2 in the front and mount a strip on the wall for the back.
I like the idea of only two in front as it avoids the access problem of reaching the back 2.
Any recommendations?
Thanks!
Roger
10/25 #2: 2 vs 4 leg levelers ...
Roger,
Attach the board to the back wall and make sure it's level and you'll never look back and wonder if you made the right decision.
The backs are set and all you have to do is dial in the fronts.
Mark
10/25 #3: 2 vs 4 leg levelers ...
Good idea, Mark.
10/26 #4: 2 vs 4 leg levelers ...
Cabinet installation is not what I do, which is why I'm asking this probably-obvious question: what part of the cabinet sits on the board that you've attached to the wall?
10/26 #6: 2 vs 4 leg levelers ...
The bottom of the cabinet (rear edge) sits on the board attached to the wall. It replaces the back two legs and eliminates any problems due to un-level floors near the wall.
10/26 #7: 2 vs 4 leg levelers ...
Ah -- I was picturing integrated bases / toe kicks, not legs.
10/31 #8: 2 vs 4 leg levelers ...
Ledger on the wall with 2 legs in front is the best system.
10/31 #9: 2 vs 4 leg levelers ...
Website: http://www.billscabinets.com
If using Granite or similar heavy counter material do you need to reinforce or double up this back ledger strip somehow since it is likely only attached to studs and not resting on the floor ?
10/31 #10: 2 vs 4 leg levelers ...
I'm not using granite, but I have 1/2" backs on the boxes so I will fasten the backs to the studs to relieve pressure on the ledge.
Roger
11/4 #11: 2 vs 4 leg levelers ...
Website: http://www.cabinetworksvictoria.com
I use 2 levellors on the front and a ledger strip on the back. Used to use 4. Got sick and tired of lying on my back trying to twist the back to up or down. Went to 2 and never looked back.
11/5 #12: 2 vs 4 leg levelers ...
When transporting the cabinets from the shop what do folks put on the back corners to preveent damage to the bases?My first thought is to put a set of plastic bases that I use for the front and then remove them when ready to place the cabinet
11/6 #13: 2 vs 4 leg levelers ...
Our levellors are 25mm tall (1 1/4") tall. We tack on 25mm thick MDF blocks we make up from scrap.
11/6 #14: 2 vs 4 leg levelers ...
What are you guys using for the ledger board?
11/6 #16: 2 vs 4 leg levelers ...
We use a piece of 3/4" x 2 1/2" scrap plywood for the ledger. 1/2" backs with screws up high in the typical place will certainly support any counter top. You can always throw more screws at it if you are concerned. The problem with legs is that only 3 out of 4 of the legs are truly taking the weight of a heavy counter.
The cleat/2 leg system is definitely one of those things worth trying at least once.
11/10 #17: 2 vs 4 leg levelers ...
I prefer 4 levelers. Mounting the back strip perfectly usually dosent mean a lot in the real world. Floors, walls, ceilings, cabinet boxes and everyting else involved is likely not going to be perfect. I like to be able to adjust everything flush and perfect on the front without twisting the boxes to conform.
As for time and cost. Plastic plinths are cheap and super fast. screwing wood into the wall would take us longer.
12/21 #18: 2 vs 4 leg levelers ...
Website: http://sunwestwoodworks.com
We tried the ledger process and found it was not worth the hassle by a long shot. Cutting the scrap pieces, the ledger, including, loading and unloading, having to cut it to size at the job site, installing it, etc., Way too much work, compared to grabbing a couple of legs and knocking them in. The adjustment process is no big deal. The thought of saving the cost of the legs was sure enticing, but in reality, for us, the ledger alternative was not cheaper. Mario
Buy & Sell Exchanges | Forums | Other Resources | Site Map
Buy and Sell Exchanges
Lumber Exchange
Machinery Exchange
Classified Ad Exchange
Forums
Adhesives Forum
Business and Management Forum
Cabinetmaking Forum
CAD Forum
CNC Forum
Professional Finishing Forum
Forestry Forum
Project Gallery
Commercial Kiln Drying Forum
Sawing and Drying Forum
Solid Wood Machining Forum
Veneer Forum
WOODnetWORK
Other Resources
Industry News
Video Library
Repeated Forum Abuse:
Forum Posting Form Guidelines
Your Name
Your Website
E-Mail Address
Subject
Thread Related File Uploads
