overlay tops how thin would you go
7/18/12
Steven R Member
We are overlaying laminate tops over existing tops they do not want the existing removed we plan on going with .50" thick
wondering if you've done it would you ever go thinner .375" ??
also have the same deal with some 3' x 6' wood desk tops thinking about .25" finished on both sides glued down with contact. edged with .375 solid wood liquid nail on edges
View higher quality, full size image (1650 X 1275)
7/19/12       #2: overlay tops how thin would you go ...
D Brown
We did an entire Bank by roughing up the existing and contact cementing the new right on top of the old , no problems.
There is more than one way .
9/23/12       #3: overlay tops how thin would you go ...
chich
same here Steve I've done this numerous times accept I wipe the whole top down with lacquer thinner and then apply a thinned out mix of contact cement over both parts, let dry thoroughly or overnite and then proceed as normal. Lets not forget belt sanding the top with 60 grit first of course
