using steel for table top bracing
4/15/13
tom
i am making about a dozen table tops for a restaurant and they have to be solid 5/4 stock. about 30" x 30 " avg size. the table bases are your standard restaurant pedastal type with just about a 6" x 6" area in middle to mount the top. no frame. doesnt look like i can put battens on these tops as they would be seen and they are looking for a clean look. I recently refinished a commercial made solid top that had a piece of right angled steel routed into the bottom of the top across the grain for warp support. i have no idea if this actually helps or works. but i am considering it. either flat 1/4" thick 3" wide steel ( much like the c top supports they sell now) or a right angle piece routered in with a 45 degree bit. am i wasting my time??
4/15/13       #2: using steel for table top bracing ...
Mark Member
Or tell them the 6x6 mounting plate on the bases is not enough support for the tops they want. Have them either cut off or a larger mounting plate welded to the existing one?
4/15/13       #3: using steel for table top bracing ...
Chris
What Mark said seems the best solution. Elongated holes for expansion/contraction
