two way drawer guides
12/7/13
keith
Website: http://keithfarrlimited.com
I need to do pullout drawers that go two ways out each side of an island. Found out the hardware is very expensive . Ive never done these and was wondering if anyone just puts two regular guides back to back to get this done? Will it work and if so, how do you connect the guides together? Was thinking about a board between them with screws in every hole.Any help would be great.
12/7/13       #2: two way drawer guides ...
mark
Sure that works fine: two regular glides, two regular drawers back to back. No problem, it opens from both sides of the island.
12/8/13       #3: two way drawer guides ...
keith
are we talking about the same thing? Im wanting one drawer/pullout that moves out both side s of the island.And wandering about the success of sandwiching two full extension guides together to get the twoway action.
12/8/13       #4: two way drawer guides ...
Henry Levy
Unless you use the proper slides the drawer will not have a centering function, it will have to be centered using a ball catch against some part of the drawer (usually the bottom to avoid any scaring of the visible surfaces.)
12/8/13       #5: two way drawer guides ...
Bobbie Everett
Website: http://www.twcsj.com
Wouldn't the Accuride 2002 guide work? It is a two way travel guide.
12/9/13       #6: two way drawer guides ...
Henry Levy
Yes the 2002 has an internal stop that centers the drawer so that the faces maintain alignment on both sides. The original question was about attaching 2 cheap slides together so as not to spend the money on the 2002. The trade price on the 2 way slides is $40.00 so I don't see how you can be thinking attaching 2 slides together is going to save you money. Richelieu has them so here is the product codes
Product #: T20022G22
1 / $ 39.57 10 / $ 36.61 50 / $ 34.11
12/9/13       #7: two way drawer guides ...
mark
Two drawer slides "back to back" attached to the same drawer, equals a drawer that won't open in either direction. But, even if you were to weld the slides together, and modify the design so that the "closed stops" were disabled, then the drawer would only open 1/2 way in either direction. So, since the best case scenario only equals one normal drawer depth access from either side, my suggestion above was for (drum roll please) two separate drawers.
Or as otherwise suggested: pay the $40.
12/9/13       #8: two way drawer guides ...
Bruce H
trying to save the cost of a guide on this one equates to "pound foolish" A purchased guide would be the easiest and least expensive approach. If you sill are adamant about saving the guide cost make the drawer using a wood runner and let the end user return the drawer front in proper alignment each time it is opened.
