Scribing a loose stile
3/25/14
Tom Member
Have any of you ever scribed a loose stile for a wall to wall cabinet. The company I used to work for did them all the time, but I've never actually seen the process of scribing one. Now I'm in the situation where I need to do one, and I'm not sure if I'm supposed to set it off the wall like a half inch and scribe from the largest gap...does that sound right?
3/25/14       #2: Scribing a loose stile ...
Carl Hagstrom
Tom - follow the link below - I think this article is just what you're looking for.
Scribing loose end panels
3/26/14       #3: Scribing a loose stile ...
shawn
Website: http://activetooling.com
i installed for years and I found it best to start from the widest gap.
most times you only need to do it once
3/26/14       #4: Scribing a loose stile ...
chuck crawford
I'd clamp it onto the end of the rails overlapping the rails equally at top and bottom. I usually use an 1" just to make it easy. Then set your scribe to 1" and mark it. Doesn't hurt to put a little back bevel on it to make it easier to get in.
3/26/14       #5: Scribing a loose stile ...
chuck crawford
My method was assuming you had the cabinet in place and the fixed stile already scribed if needed.
3/26/14       #6: Scribing a loose stile ...
Tom Member
Chuck, when you set the loose stile back an inch and clamp it to the rails, do you set your scribe to an inch plus the farthest point (or largest gap)? I'm just having trouble working this through in my head.
3/27/14       #7: Scribing a loose stile ...
chuck crawford
You asked,
"Chuck, when you set the loose stile back an inch and clamp it to the rails, do you set your scribe to an inch plus the farthest point (or largest gap)? I'm just having trouble working this through in my head. "
No you just set scribe to 1". Assuming this is the right hand stile that is loose and you lap it over the rails an inch and clamp it you just need the left edge of that stile to move exactly 1" to the right to drop into position. So if you set scribe to 1" and follow the wall and remove everything to the right of your scribe line it will drop into place and fit the wall.
Probably made that as clear as mud huh.
3/28/14       #8: Scribing a loose stile ...
Jeff Guild
What I do is first rip the stile to the widest with on the table saw then if the wall is out of plumb I push the stile up tight against the wall at the narrow part pull the wide part out away from the way so the stile is even over the rails a then mark a line. I use a hand held power planer to take a lot off. or a low angle block plane to fine tune
3/30/14       #9: Scribing a loose stile ...
The upper cabinet is in place.
Hold the stile up to the wall
Make a light pencil mark at each rail
Adjust your scribe to the mark that is furthest from the wall
Make a mark on the other rail with the scribe following the edge of the rail
Hold the stile up against the wall at the narrowest part of the opening and to the mark on the rail, that is furthest from the wall.
Adjust your scribe a smidge narrower to make the stile snug
Run the scribe along the wall, making a pencil line on the stile.
Clamp the stile to something to cut it on. ( I used a stool that I made with a surface on top)
Cut the scribe at a steeper angle than normal to allow the stile to rotate into position.
Trim the dowels to allow the stile to rotate into position.
A little glue and tap the stile into place.
