Options for supporting an installed 22" semi-circular granite overhang?
3/31/14
Brian Cain Member
The kitchen island has a 10"x49"x3cm unsupported overhang that runs into a 22" radius semi-circular overhang at one end. This has been supported by fabricated supports that prevent comfortable seating around the countertop. The home-owner has had the cabinetry refaced, which required removal of the supports. He requires to replace the supports and has specified a centrally-located island leg with a plywood crown. Any thoughts, options and advice will be gratefully received.
View higher quality, full size image (634 X 571)
View higher quality, full size image (678 X 626)
4/1/14       #2: Options for supporting an installed ...
JeffD
Personally I don't think I'd like a center post there at all. I think if I were to tackle this I might suggest a nice thick curved apron set in from the edge of the granite maybe 6" or so. If necessary the apron could flare down at the connection with the cabinetry for greater rigidity, though if tall enough it may not be required?
good luck,
JeffD
4/1/14       #3: Options for supporting an installed ...
Brad
We use 1/2" +- thick plate typically about 4" wide under large overhangs which is fastened to the top of the cabinet prior to counter install. Any local steel shop can easily cut and drill these for you. Haven't had a failure yet... I would clear with granite company though, as them may have some requirement to maintain their warranty.
4/2/14       #4: Options for supporting an installed ...
jim
What Brad said. Sand a bullnose on the plate steel, primer ,paint ,done.
4/2/14       #5: Options for supporting an installed ...
Brian Member
Guys, thanks for the input. As the granite is already installed we're going to cut back the original supports (whichwere over engineered anyway) and reinstal them. It's a cost and convenience thing.
4/10/14       #6: Options for supporting an installed ...
mark
No, Brian, it's a planning thing.
