Crown return off a 135 degree curve
7/6/14
Dave Member
Hi. Looking for suggestions on how to solve for a 135 degree radius turn on a soffit with some sort of crown return with only 2" available at the end of the soffit? When I tried to cut a standard return, the piece was larger than the 2" available. I am butting the top piece into the top of the soffit, but any suggestions on how to complete the bottom of the soffit will be greatly appreciated. Thanks.
7/15/14       #2: Crown return off a 135 degree curve ...
Rick W
That's a difficult scenario. I hope by now you've found a solution.
The only thing I can think of is to return the end of the crown, but to end the return right at the corner.I don't see a practical way to incorporate that 2" section of the wall. As you said, the piece of crown for that section of wall would be longer than 2".
Good luck!
Rick W
7/15/14       #3: Crown return off a 135 degree curve ...
Why would you simply return the crown as normal and chop the return at the rake angle? It may be tedious to piece together up there but if you built the return on the bench, fitting as you go, then once you had all but the return together glue the lot together and chop the rake on the miter saw or table saw?
Perhaps Im seeing it wrong.
4/28/15       #4: Crown return off a 135 degree curve ...
Id return it to itsself on the wall before it angles and make the furthest top tip of the crown end where the angle jogs out the 2"
