refacing options - natural oak to white painted
10/17/14
Robert Ring  Member
I have a refacing job coming up where the existing red oak cabinets will be refaced as white painted cabinets. I'm replacing the doors, and I planned on refacing the frames using PSA veneer cut to rough width and prefinished in my shop. My dilemma is how to deal with the exposed edge of the shop-painted PSA veneer once I apply it and trim to final width onsite. I'm trying to avoid painting the entire refaced frames onsite, but I'm not sure if there is a good way to just "touch up" the newly exposed edges of the trimmed psa veneer. I'm open to any and all suggestions / alternatives, since I suspect I'm failing to see the most obvious easy solution (as is often the case). Please let me know if I need to provide any additional info about the job or my operation to help focus your response.
Thanks in advance,
Rob
10/18/14       #2: refacing options - natural oak to w ...
RichardP
Perhaps if you were specific about what you mean by "painted".
Richard
10/18/14       #3: refacing options - natural oak to w ...
Robert Ring  Member
That's actually a good question. It depends. If I do everything in the shop I'll spray pigmented lacquer. If I need to do some color / coating work on site I'm not sure my best option - maybe Benjamin Moore Advance (waterbourne alkyd resin) or Cabinetcoat - something I can spray in the shop and brush on site. Does that answer?
10/18/14       #4: refacing options - natural oak to w ...
mark
Typically natural to painted changes are made by simply painting the cabinets. Hire a painter, and charge what you charge. It's all new cabinets to the client.
10/19/14       #5: refacing options - natural oak to w ...
I've seen pvc edge banding up to 55mm wide. No painting at all if that is wide enough and color close enough. Solid color high pressure laminate may be another option.
10/19/14       #6: refacing options - natural oak to w ...
Robert Ring  Member
Thanks for the suggestions so far.
Mark, painting the existing frames would have been my default approach, but the existing cabs are oak and the new doors will be painted soft maple. To my eye, painted oak still looks like oak. Would you take the extra step of filling the grain first?
10/19/14       #7: refacing options - natural oak to w ...
mark
Not for a typical refacing budget. It's probably already got a lot of finish (grain filling) on it. Just level sand, prime and paint: that's a lot of build.
