Built in design ideas/solutions?
11/13/14
Russell Tribby  Member
Website: agapewooddesign.com
I have a couple of built ins on my upcoming schedule and one of them is a floor to ceiling unit. The homeowner had coffered ceilings installed and had them stop short of the back wall by 18", the depth of the upper cabs. When they installed the beams they divided the room into thirds, the result being vertical lines that the pillars of the built in will not match up with since the specs require a middle section that is twice the width of the flanking sections. Additionally, as I see it the front surface of the uppers will have to be flush in order to meet the back side of the crown. That will mean 16' of flush uppers with no reveals or changes in depth - not ideal and not how this was drawn up. Any ideas/suggestions on how to tackle these issues?
View higher quality, full size image (2000 X 1500)
11/14/14       #2: Built in design ideas/solutions? ...
Josh Koschak Member
At a minimum, can you play with depths of the bottom unit?
Also, if you maintain symmetry off the beams, and are at least a couple inches off from alignment it will look fine in my opinion. Then it wont look like a mistake.
Follow up when design is complete, looks like a fun unit to build.
11/14/14       #3: Built in design ideas/solutions? ...
mark
As long as you have enough depth in the soffit above to catch your crown, then you are fine. Yeah, others could have done better with their work, or perhaps, you could have communicated a little clearer. Nevertheless, build what you drew. If they had your drawings ahead of time, then they'll get what they expect. Don't make it a problem, if it's not.
11/14/14       #4: Built in design ideas/solutions? ...
Tom
Website: http://tpgcabs.com
I handled a situation like this recently by building a soffit about 8or 10" high, below the coffered ceiling,painted it the color of the walls and then built the wallunit as planed below the soffit.
11/18/14       #5: Built in design ideas/solutions? ...
Jeff M
I don't see an issue here. The unit itself is balanced, the ceiling is balanced....they are separate things and probably shouldn't line up with each other. The change in depth from your columns to the arched faces behind will be enough IMO.
11/18/14       #6: Built in design ideas/solutions? ...
Russell Tribby
I discussed the ideas with the homeowner and we both agreed that a small soffit, dropping just a few inches below the existing crown was the best option. I appreciate the advice given by all of you. I'll be sure to post pics when it's done.
11/28/14       #8: Built in design ideas/solutions? ...
Paul S
Do it the right way.... have part of the coffered ceilings removed on the back wall....Add wall bump out on right side, Install integrated cabinetry with the new modified crown as it should be with this type of work.....do it right otherwise it will look like and will always look like someone screwed up !!!
