Installing a Island over a tiled floor with in floor heat
4/20/15
Tom Member
I need to install an island over an already tiled floor with geothermal in floor heat, I have never done this and am not sure what the best way of going about it is. Can I glue down some sort of 2x4 blocking to the tile then screw through the deck of the cabinets into them to fasten it? If so what kind of glue would I use, and would I be able to sleep at night doing this?
4/20/15       #2: Installing a Island over a tiled fl ...
mike
somehow I avoided ever being in this situation. I would be skeptical of glue holding long term especially if you have an island that could tip over. Two idea's for finding the hydronic heat. 1st is to wet mop the floor, turn on the heat, and see where it dries first. ( a plumbers trick) If you get distinct lines you can be fairly certain where the pipes are. 2nd is to have an insulation sub come in with a thermal camera to detect the pipes. Still, there is some risk and I think I'd be talking to the homeowner or contractor as to who assumes the risk if a pipe is hit. Maybe if it was a large enough, stable island with no chance of tipping I think a large surface area of blocking or full plywood glued to the floor would suffice.
4/20/15       #3: Installing a Island over a tiled fl ...
Never done it, but I'd say a good silicone adhesive would work fine on the 2x4s because of all the glue area. Can't guarantee it though.
4/21/15       #4: Installing a Island over a tiled fl ...
dustin orth
We have used 2x4's that get liquid nails squirted on the floor face approximately where they need to be final, set the island over it. Then screw into the 2x4 from the toe kick face, the glue may slide some but will be where it needs to be. We then apply a finished toe kick over that and your done. Make sure nobody bumps it for at least 12 hours and your golden. This works great unless you have a massive overhang on a small island with out a lot of footprint.
4/28/15       #5: Installing a Island over a tiled fl ...
Riggles Member
If you want the island to be NEC compliant, someone's going to have to drill: "At least one receptacle outlet must be installed at each island countertop space with a long dimension of 2 ft or more and a short dimension of 1 ft or more [210.52(C)(2)]".
