Poplar for sauna walls
4/20/15
dan Member
Need to re-panel walls in a sauna....
Not using WRC due to discoloration and excessive cupping in current material.
Poplar, which I can buy locally, is much more affordable than Alder, which would be 2x's the cost.
Question is will "regular" KD material from a DH (lower temp) kiln stay stable?
4/20/15       #2: Poplar for sauna walls ...
Wet sauna or dry sauna? Poplar has almost zero rot resistance.
4/21/15       #3: Poplar for sauna walls ...
dan
Dry, there is a separate steam room.
My plan right now is to temporarily put some poplar on the wall and see how it reacts?
5/15/18       #4: Poplar for sauna walls ...
Xedos
I’d try to find a new supplier.
Cedar has been used successfully in saunas for about a century. If yours is cupping then it’s been installed improperly or it’s just crap material.
Poplar isn’t going to be any better than cedar regarding the stains. You just gotta get used to it.
