painting cabinets
8/31/15
Brandon Hubbs Member
I just started building cabinets and I have never painted cabinets before. Anyway I need to paint a set white. My questions are what wood, paint, lacquer should I use?
9/1/15       #2: painting cabinets ...
Spicolli
3/4" prefinished ply for cab boxes, soft maple for face frames/door frames, mdf for door panels, bondo for any defects that need filler. I like SherWill HiBild precat lacquer that is tintable, can also be used as a sealer. One heavy sealer coat, sand smooth, followed by two finish coats.
9/2/15       #3: painting cabinets ...
Frank
I wish everybody that posts responses would be as helpful and nice as Spicolli.
9/2/15       #4: painting cabinets ...
Jim Herron
I like Poplar or Soft Maple for frame parts and mouldings.
MDF for panels. I spray a clear precat lacquer thinned 50% on machined areas prior to sanding, followed by white vynil sealer. Fill any joints or imperfections with a THIN fill of automotive glazing putty. Sand and reseal any sand thrus.
I use pigmented precat lacquer $$ or pigmented conversion varnish $$$ for topcoat, as it will be dust free in minutes and dries hard in a few hours, followed by optional glaze and 20 degree clear for those willing to pay for it.
Trick is to get any imperfections corrected prior to the last primer coat.
9/4/15       #5: painting cabinets ...
sparsparkster
I'm painting a table top is not paint enough?
Should I put a lacquer over paint? Shows how much I know about finishing!
9/6/15       #7: painting cabinets ...
Lacquer over paint?? Probably not a good idea unless the paint is a compatible lacquer also.
