Nail hole touch up on Conversion varnish
12/21/15
Jake Member
We are a in house millwork shop for a custom builder and do built ins along with some of the millwork that requires finishing. Recently we switched to conversion varnish to try and avoid having to go back and do so many repairs . Pre Cat Lacquer was just not durable enough
Now after filling the nail holes with Mohawk fill stick we are seeing shinny spots left after cleaning off the excess. We have been trying to take off the wax first with a damp rag with mineral spirits but still can see the shinny area. Any advice
http://zaveta.com/capabilities/
12/21/15       #2: Nail hole touch up on Conversion va ...
Shaun
Magic eraser takes off mohawks patchal putty on both CV and lacquer.
12/22/15       #4: Nail hole touch up on Conversion va ...
JM
We do it one of two ways. Small touch up brush with some paint, and just drop a dot of paint in the pin hole.
Second way is with a wax stick. We use a rag wet with naphtha, wipe the surface, rub the wax in. The key is to keep the surface wet with naphtha while rubbing the wax in.
12/22/15       #5: Nail hole touch up on Conversion va ...
kevin
the shine your getting is from the rubbing. its like buffing the area. Best way to avoid it is to use a plastic razor to remove excess. then as stated above use a rag dampened with a bit of mineral or naptha. AVOID RUBBING hard and keep the rubbing to a minimum.
If you are trying to correct some spots that have already been rubbed to a shine, a quick fix is to use a can of mohawk aerosal precat in the sheen desired. just spray a real light mist of the area affected and it will dry down to unnoticeable
12/30/15       #6: Nail hole touch up on Conversion va ...
John Member
Shoot the nails through 3M's tape for delicate surfaces. Then use the wax sticks and wipe clean. Finally, pull the tape. If you have to wipe more afterwards, do so gently. You can leave the tape on for up to 2 weeks if the finish is fully cured, but it's best not to.
John
1/3/16       #7: Nail hole touch up on Conversion va ...
RobertJ
John's idea is hitting the nail on the head.
Simply a fantastic solution. Why didn't I think of that. Perfect!!!!
