i need to find the tool for these
6/15/16
collin kellner
I'm remaking the doors on these cabinets, but I have no idea how to get the hinges to mount to my new doors, I need to find what ever tool or router bit is for these
View higher quality, full size image (2688 X 1520)
6/15/16       #2: i need to find the tool for these ...
mike
search Amerock Double Demountable Cabinet Hinge. And Amana has the cutter.
6/16/16       #3: i need to find the tool for these ...
Matt Krig Member
If you only have a few of these to do unscrew the face frame tab and knock the screw out with a hammer. Then you can drill a pilot hole in the frame and simply use a single screw to the frame rather than route a hole and clamp. If you can't find someone reasonable and easy to route the doors on an Amerock machine just buy the bit and make an "L" shaped fence on a router table and do a horizontal plunge type cut. if you make a square 90' corner even behind the bit, you can cut lefts and rights on the same setup.
6/16/16       #4: i need to find the tool for these ...
collin kellner
Thanks guys I found the exact bit I needed
