Salice Air Hinge
11/10/16
TimG
Need input on this hinge, the good,bad, and the ugly.Looks like a neat solution, how much trouble is it to use,Ect?
1/18/17       #4: Salice Air Hinge ...
I love the look and idea. I've only seen one place with pricing on them, YIKES!!!!!
1/19/17       #5: Salice Air Hinge ...
Hello all,
I thought I would chime in on this topic to detail what exactly is the new Salice "AIR" hinge.
The Salice AIR hinge was a 2016 IWF Challengers Award winner for innovative new products in our industry.
This is a totally new concept in concealed hinges for contemporary cabinetry and furniture. The AIR hinge diverges from the concept that a traditional "cup" hinge must be the order of the day when a concealed hinge is desirable.
Although the AIR hinge is only 3/8" in height, it offers exceptional strength. Only 2 hinges are required for even very tall doors (Up to 24” X 84”). Due to the installation position, it does not encroach on any interior cabinet space and is nearly invisible. The AIR hinge is available with soft close or “Push” to open and you can select from the nickel or Titanium finishes. The AIR hinge can be used with wood doors or a specialized aluminum profile door offered by Salice.
A new installation technique must be studied to use the AIR hinge. At this time a 5 axis CNC is the best equipment to machine for the hinge. A template will soon be available that will allow the machining to be done by hand with a plunge router.
Here is a product bulletin and spec sheets for both a wood door and an aluminum framed door. Most Salice distributors are now beginning to stock the AIR hinge and samples are available.
View higher quality, full size image (1264 X 1632)
View higher quality, full size image (788 X 1048)
Link: Salice AIR Hinge Details
1/19/17       #6: Salice Air Hinge ...
Clark Member
Thank you for this information!
