Edgebanding same as case or doors
1/23/17
Chris
Got a debate with a friend. We both mainly build prefin maple boxes. He bands in prefin maple banding. I band in whatever the fronts are. Paint grade gets paint grade, stained gets stained. I realize PVC in a like or matched color is an option but neither of us like it. With the PVC option aside, which do you do?
1/24/17       #2: Edgebanding same as case or doors ...
I match the fronts always.
1/29/17       #3: Edgebanding same as case or doors ...
Gerry
Mostly we match the fronts. You don`t want to see a big contrast like white or natural maple with dark fronts because it will jump out at you between the fronts.
3/13/17       #4: Edgebanding same as case or doors ...
D.Morris
We always have went with the face color. We just recently started experimenting with leaving them PF-Maple like the interior. Just finished a big Home Show with 3 displays. We left our darkest display's banding PF. This one had the most contrast of all the displays. Cabinets are a dark raw-umber. Over 1000 people looked at the display, opened the doors, Loved It! Not a single negative comment about the PF edgeband. We will likely transition to this as our standard. Much easier!!
3/20/17       #5: Edgebanding same as case or doors ...
Ikea, leaves it maple pvc, so it must be ok,right?
11/11/19       #6: Edgebanding same as case or doors ...
Brendol  Member
Website: https://www.houzz.com/pro/brendol-scholz/creative-...
We match the doors and fronts. It wouldn't look right for a light natural maple to show between the doors etc.
